May 29, 2006 #1 T turbolc2 Mongoose Joined May 25, 2001 Messages 156 Which exhaust manifold gaskets are you using if any?..Do they live very long and can they be trimmed and still seal up?
May 29, 2006 #2 B Bobs rare 6 Member Joined Apr 11, 2004 Messages 654 I use felpro-1400s. They work good and have the big ports. Later, Bob.
May 29, 2006 #3 T turbolc2 Mongoose Joined May 25, 2001 Messages 156 Bob's Rare 6 thanks for the imfo.
May 29, 2006 #4 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 take a belt sander to the header and make sure the flange is flat, then use copper rtv and your done. i do this to the turbo flanges also, havent had any leaks...
May 29, 2006 #5 D disco stu Active Member Joined Apr 10, 2002 Messages 2,562 Fel Pro 1400's for years, no problem. Retorque after a few heat cycles.
