What sensors can go bad and then be bypassed by limp home mode?
For example, I know the car will run with the MAF disconnected. Does that put you in Limp Home mode for ALL sensors?
Would the car run with the CAM sensor disconnected in a similar way? If so, why does Caspers sell that CAM FIX Module?
Also are there different kinds of limp home mode. For example, a sensor going bad, might give you one result, but what about if the entire ECM dies, is there a different limp home mode?
My car starts, and immediately dies after 2 -3 seconds. Unplugged the MAF and the result is basically the same. Trying to understand what I can unplug vs what I can't as a process of elimination.
