external wastegate size
Nov 14, 2005
680
6
18
118
Amherst,NY
I have a ta49 turbo and I am going to get a downpipe. I think I am going to go with an external waste gate welded off the pass header before the turbo. What size wastegate would be good to use a 38mm or a 44mm. I will probably upgrade the the turbo later on to a 6262 so I would rather buy 1 that would work for both turbos if possiable .
RUQWKNF
KEEPER OF SECRETS
Staff member
May 26, 2001
2,427
292
83
47
NEED TO KNOW BASIS
s78.photobucket.com
I agree with Chuck.
One 46mm external gate is enough wastegate to support 650 fwhp when setup correctly.
It's easily enough to control a TA-49 turbo or a 6262.
FWIW, I'm currently running one 46mm on my PT6766 setup with perfect boost control. Mounted on the downpipe with the hole ported and contoured.
Just to recap, a single 46mm external is plenty of wastegate for a bolt on / mild combo.
-Patrick-
  • Like
Reactions: V6sleeper
Top Bottom
