F body radiator
RUDE DOG
Rudeawakening
I did a search already and nothing comes up. What are you guys using to hold the f body radiator in place?
Are you using v8 shroud or aftermarket, custom,,,,,, I need to get this done and out the way asap. T.I.A!
I have one you can have for shiping. It is a V8 radiator hold down plate that bolts on. It does need paint and I can send you a PIC. This is from an Old Gbody and is the same as on an 87 TTYPE. Brad
I'm using the top bracket from an 86/87 TR.
Thanks for the info.
Thanks for the offer Brad, but I think I might have one in the other garage where the 54 is at, ill check and see if I have one first. TOO COLD!! to work on a 54, but not cold enough to work on the TR.
