I've had the car for 3 years and put only about 500 miles or so on it. It's not my daily driver. The car has 87,965miles and was mostly original when I bought it. The paint is good, but not great. it's got a few minor spots that could be fixed, but it doesn't need a paint job by any means. No rust anywhere. Good window seals.
Parts
John Craig TA-61 turbo
PTE front mount intercooler w/polished pipes
Braided stainless turbo oil and return lines
RJC power plate
Lower intake has been ported w/ new inntake gasket
CC980 valve springs
Armstrong XP fuel pump w/ hot wire kit
Volt booster
42.5lb injectors
Extender chip
2 Red Armstrong Chips R93H and R100H
LT1 Maf
Maf Traslator Plus
K&N Cone filter w/chrome intake pipe
Terry Huston Stainless Downpipe w/ dump
Flowmaster exhaust
Vurtually all new sensors
9/11 torque converter 3500 stall
tranny cooler
S10 Rear brake cylinders
New Power master
Direct scan
Autometer Boost, water temp gauges
Caspers Knock guage
3 Switch ashtray switch plate (linelock,TClockup,fan All not hooked up)
Hood mounted Fuel pressure guage
Adjustable FPR
New Springs in rear w/ RR airbag
90/10 shocks in front
American racing wheels 15X7 front 15x8 rear
Nittos Drag radials
Matching set of wheels with MT ET Streets
The interior is clean, but faded a little, and there is a rip in the driver side seat. I have T-type embroidered floor mats. The top dash panel is split, but I have a new one, just needs painted and installed. I can't think of anything else, but I have reciepts for over 5000.00 spent on the car, excluding the cost of buying it. I have some of the original parts from the car, but sold the wheels and intercooler. I've had it at the dragstrip when the master cylinder sprung a leak, so I couldn't hold any boost at the line. With 116 fuel and 21 pounds of boost I went 12.01 @116.5 and that was the first time at the track with this car. I was leaving with zero boost off the line. My sixty's were in the 1.85 range. After that I replaced the powermaster with a new unit, and put a new TCC lockup solenoid in the tranny. Like I said the car rarely gets driven and has always been garage kept while I had it.
11,000 obo
Email me for pics, and any questions. Thanks Mike
Parts
RJC power plate
CC980 valve springs
Volt booster
42.5lb injectors
Extender chip
LT1 Maf
Maf Traslator Plus
Flowmaster exhaust
tranny cooler
New Power master
Direct scan
Caspers Knock guage
Adjustable FPR
Nittos Drag radials
11,000 obo
