Factory Tach Way off
ecna
My factory tach seems way off. I have not hooked up an aftermarket to give you exact numbers and I have not driven the car hard since I just got it so I can't say how far it's off at higher rpm. It shows about 4000 rpm when I would say it should be about 2-2500. I do have another dash and can swap it if you think it's the problem. What else could be causign it to read so inaccurately?
Thanks,
Eric.
Thanks,
Eric.
AGE they were never accurate i think they were there just to let you know something was going on . the same goes with the boost gauge
Mine actually reads 1000-1200 when it is really idleing around 800. Scanmaster helps out with that giving the correct rpm.
