87 Turbo T
Anyone ever have a problem getting a good contact with them to the selonoid due to connector problems. I was noticing my high speed fan was not coming on when it should both with car on/off. After a little investigation I noticed if I wiggle the connector to the selonoid it would come on intermittently. I pulled all of the connectors and noticed they had started to deteriorate at each contact. The plastic looked as if it was melting. I don't know if this is due to high heat or what? Anyone else ever have a similar problem with the relay connectors? Where can I get new ones? Any help would be greatly appreciated.
Thanks!
Rob
Thanks!
Rob
