Fast Pwr Window Kit
jpratt
I bought the fast power window kit from Kirban but I am having a little problem. the instructions say to use the pink wire with the black connector under the dash. I have looked and looked but can not find a single wire in a black connector. Has anybody else installed this kit succesfully? Where does the pink wire with black connector lead to? Everything else plugs right in. Frustrating I know the wire is there somewhere but I cannot find it.
In the fues box? The directions that came with said that they are just hanging out. The pink w/ black connector is loose and used only for the cars with the astroroof. Did you use a wire from the fuse box?
that connector is supposed to be plugged into the fuse box mine has the power seat orange wire plugged into it
