SignUp Now!Originally posted by stangbanger
My times were run in Bowling Green, this year. I've been running 10s the last 3 years.
Originally posted by jastrckl
smoking fast for that turbo and weight. gotta be some black magic in that one.
ITSAV6,
You don't have to be from Ohio to have a Raptor..........You just have to know someone from Ohio.![]()
You're right, Brick, I do run a lot of boost.
On the 10.66 run, I unknowingly had a malfunctioning wastegate puck that would only open about 1/4". Needless to say, I don't know how much boost I was running. I normally would get out of the throttle under these circumstances, but on this run, I didn't notice it until the 1000' mark. The car was running clean and flying, so I decided to stay in it. It pushed an intercooler hose clamp off in the traps, which cut the mph to 125. The car didn't have one of it's best 60's on that pass....1.53. I believe with a killer 60', the hose clamp staying on, and if the heads and crank would have stayed connected to the block, that pass would have been a 10.50.
After repairing the wastegate, and getting the boost gauge needle pointing to a number, I ran back to back 10.78s. Again, with less than stellar short times. Boost was in the 34-35 range.
The 126.4 mph came on a crappy 11 teen run in the semi's of TSS.
ITSAV6,
