SignUp Now!stephan said:Take a look.........
00153 274 cid
GM S2 head ported from Chapman
pt 88 turbocharger
came from dls
fast sys mangement
KLHAMMETT said:Although,too much power to be relying on a powermaster brake unit![]()
I just scrapped mine
TURBOKID said:What size are your rear tires and did you cut the frame to fit them?
John Wilde said:Thread Hijack warning:
What do you think of the new TCI Pro Mod Converters???
They seem to work well in the DR Mustangs.
Big Stu said:John, my friend jeff has a 98' camaro with a pro-charged 488 small block. He tried the tci and trashed not only the converter but his new freddy brown glide on the 4th pass.He told me he is going back to the neil chance and that tci sucks. He builds all his own engines and does all his own tuning and makes 1480 plus at 34 lbs of boost so I don't know.
That is my only info on them.
86brick said:They look to be 325/50/15 MT DRs?? If so I'd bet the frame has been notched...
stephan said:right on LOL there it is a set of 325/50/15 MT DR
outer frame a moved of 1-1/2 inside
and the lips are cuted.
-------Although,too much power to be relying on a powermaster brake unit
I just scrapped mine----------
i will dont need my powercrapster
for cranking it, the transbreak will hold it on the line.
thanks a lot for comments
John Wilde said:What are your plans with the car?
It looks really nice!
stephan said:I am in hope to touch 9
but alot of work and tunning left
thanks John
86brick said:Nice! Looks very good with those tires and should be great for the track (both Tony Gomes and Cal Hartline have runs 8's on those tires) as well as the weekend outing![]()
stephan said:thanks for comments
You know where can i get
those video ? ( Tony Gomes and Cal Hartline )
let me know
thanks
86brick said:Here's Tony Gomes's 8.48 @165mph pass from behind...
http://www.swcyber.com/nightmare/TonyGomesAtco2005_8.48.wmv
And I believe this is the same pass just from a different view (Tony is in the far lane obviously)..
http://www.swcyber.com/nightmare/Jose&Tony.wmv
Tony blowing the tires away..
http://www.swcyber.com/nightmare/TonyGomes.wmv
Don't know of any video of Cal running 8's on the M/T DRs, but he did indeed run 8.83 @157mph if my memory serves me correct and he did it with the GT42R 76mm turbo...
