For those of you looking to pick up a Fiberglass Hood at the Reynolds, GA Event, Place your order ASAP! We will bring a limited supply to this event. The hoods are $495. They are double layer TOP QUALITY contruction and finished with Black Gel Coating. These hoods use stock hinges and you can install a hoodliner on them. You will need to change out the struts and relief spring. To place your order call Hartline Performance 321-722-1563. ~Thanks, Holly Hartline
