TURBOTERRORV6
The Street killer V6
- Aug 20, 2005
Wow, after a hell with this car for one full week trying to figure things out, researching and researching, Reading, learning new things with these motors!. Thanks to the help of TB.com, Gntype.org, and members in this site!.. this baby finally turns on. i must admit i learn very much going through this site! Wow..thank you..
Anyways now that we figure how these motor work somewhat, and its basics. here is some questions that hopefully some of yall knowledgable members might help us..
what is the recommended torque or adjustment procedure for tighten down the rocker arm bolts? we are running a 206/206 flat tapped cam from comp cam(cotton ordered), also due to the aftermarket cam we are running, what is the best adjustment to the cam sensor?and balancer.. currently the balancer is set at 25' degrees ATDC with the cam sensor locked at .40 voltage. ( window facing 3'o clock). car cranks right up, but when you step in the gas or throttle,it kind of hesistate, doesnt sputter or misfires. through all RPM.but like a miss when you move the throttle.
currently the mods are:
206/206 flat tap cam from comp cam
Comp cam double roller timing chain
orange strip 3100 non lock up stall
and basically everything else is stock..
THANKS to all
THANKS to all
