I recently installed the LT1 MAF , translator, hot wired fuel pump, CS-144 140 amp alternator, Billet Servo, Mega valve & 160 degree therm. The car idles tons better at 750-775. The BLMs are at 105, but was 150 before the MAF. Now the MAF shows 7 gps at idle vs 3 gps and the IAC is at 10-13. The fuel pressure is at 44 vac/off and 40 psi with vac/on. The only thing that concerns me is when I rev the car above 3K rpms, the voltage drops to 12.2 from 13.8. Unless the battery is tired from sitting for 3 weeks, the alternator should be able to handle anything. The throttle is definitely more responsive when I rev the engine and sounds great. I'm going for a drive shortly to check the shift firmness. I'm hoping for a 1-2 bark and very firm 2-3.
I guess next are the valve springs( I have them. 100 lb) & converter. The previous owner claims to have installed a non-lock-up B&M, but I have learned to take his comments with a grain of salt. I'm interested in the Extreme Duty Power Raptor Lock-up. It's a 9 1/2 with a 12" Carbon Fiber clutch. This will be in the fall.
