Hey guys. Just finished porting/polishing heads today. Carefully smoothed out chambers (tried to not take much material out here). Opened up/shaped intake and exhaust bowls enough to smooth and get rid of ridges and imperfections. Reshaped guides; smoothed and tapered a bit on the exhausts, and smoothed and shaped the intakes in a kind of "V" shape (didnt want to grind down guides as this is primarily a street car). Port matched intake and exhaust ports to gaskets. Took enough material from inside of ports to smooth out ridges, imperfections, and unwanted casting nonsense/slag; and to square up and match openings. All smoothing and reshaping was done with the thought of promoting air flow.
These are the first heads that I went to this extent on. I was planning on bringing them by the machine shop I used to work at and let the head machinest check the basics for me (seats, guides, valves, springs, and to see if they need any resurfacing).
My question is: should I be worrying about bringing them somewhere to get them flowed first?
Thanks, Justin.
P.S. also, while Im at it, what valve guides should I go with, if needed? Bronze?
Thanks, Justin.
