Got mine from Full Throttle. I moved the maf to the outlet of the intercooler and used a 90* piece of 3" pipe to connect the maf to the throttle body. I used a 2 1/2" to 3" adapter hose on the intercooler outlet and at the throttle body. Relocating the maf there would probably be a lot easier with a fmic since there's more piping to be able to mount the maf into. I connected the maf pipe to the 14" K&N. I also made a support similar to what the TTA uses to hold the pipe in position. I had to trim each end of the maf pipe so it would fit- not a big deal if you havew a chop saw. Just had to trim- fit- trim- fit until it cleared the generator pulley. HTH
Mark
