For Sale: Seiman 83 lb injectors
hello; I'm not interested in your injectors but tell me. As you increase your injector size I was told your idle goes up? If that's true what was your idle with 83 lb. injectors?
IBBY
IBBY
Your idle should not go up. If your tune is good it should idle like stock. Vacuum leaks, bad iac, tps will cause higher idle.
