Jay Carter has a variable timing chip using a boost harness. If you run a translator, you can now mount the ATS in the up pipe.
If you pull timing as boost rises you can raise timing in the main timing table. The instant boost rises, the ECM will pull timing.
If you use the ATS there is a delay before the temperature rises while the IC initially soaks up heat. By pulling timing with temperature, the higher timing would stay in longer by pulling timing only in response to turbo inefficiency, not just boost.
Has anyone compared the 2 methods? I was planning on moving the ATS but if one way was obviously better than the other I would do what works best.
