Mar 12, 2004 #1 B Billdogg PSI FED 6 Joined Jun 12, 2002 Messages 626 Will the frame from an 87 GN swap with an 86 El Camino frame?
Mar 12, 2004 #2 O olds443 Active Member Joined Aug 21, 2002 Messages 1,272 I believe all the 2 dr G bodies are the same but the El Camino has a longer wheel base so it won't. I am not sure about the 4 dr g-bodies.
Mar 15, 2004 #3 T turbofish38 Le Pétomane Joined Dec 3, 2002 Messages 6,160 No they will not. ElCamino wheelbase is 117" all others is 108".
Mar 15, 2004 #4 T turbofish38 Le Pétomane Joined Dec 3, 2002 Messages 6,160 But everthing that is bolted on will. The extra length was added on the straight section of the frame.
