Hi
My front suspension (87-T) has had problems ever since I installed the Performace Suspension Components front end kit with heavy duty sway bars and Eibach springs (1") drop. My problems are as follows.
1. My drivers side a-arm has excessive shimming +/- 1 " of shims (toward firewall.) My pass side has one or two shims.(Normal)
2. My sway bar hits my tires..lock to lock, and is pressed up against my idler arm.
3. Most important problem is that my inner tie rod ends are digging into the crossmember of my frame.
4. The car drives fine, tracks ok, and has never been wrecked, but it seems to have excessive bump steer.
5. Could I have bent the a-arms putting in bushings and balljoints??(sledge method)
Any help with these problems would be appreciated. This problem has been with me 1 year now and I would really like to fix it with the lowered ride height. I have an 87GN with stock suspension and when I compare the two, it seems as though the tie-rods have moved inward aprox 1". I have contacted PSC who gave me the number to Hellwig products, their manufacturer who suggested "shimming"the sway bar but cannot help me with the tie-rod ends.
I am willing to do anything but raise the car to the standard height.....I have seen many lowered regals who did not have this problem
I have "copious"amonts of pictures and will e-mail to anyone willing to help
Jim
Jim
