Hello all,
Gathering information/parts for my winter project which is rebuilding/replacing/restoring the stock(ish) suspension. I'm not looking to drag race, autocross or anything like that. Just a nice solid cruiser I can still have a little fun with in the curves.
Starting at the rear, I have a set of HP motorsport non-adjustable upper and lower control arms and stock rear roll bar. I put these on back in 1997 and haven't touched them since. They have poly bushings that are able to be greased. I also have new Bilsteins on all four corners.
Question 1: Is it worth replacing the control arms or at least the uppers to adjustable?
2. I know the factory bar is tiny, what would be a good stock location replacement?
Now for the front. Bone stock. Hasn't been touched since I bought the car in 1994. I'm guessing after 37 years the stock rubber is pretty well shot along with the springs. I don't necessarily want to lower the car due to some of the roads and driveway approach angles around here. To be fair I've been out of the GN game for years and haven't kept up with the latest and greatest. Last time I knew, S10 lower control arms were a thing and polyurethane bushings were bad because of squeaking. I've been lurking in the sticky threads and all that did was give me a headache.
Question: Is it better to keep the stock upper and lower control arms and just replace the bushings or replace them?
2. Last I knew f-body hollow sway bar was the way to go for the front. Still true or no?
3. Best bushing material for my application?
4. Tall ball joint. Can they be used on the stock control arms?
5. Spindle/caliper/brake upgrades that will fit behind 16" GNX replicas? Worth it or no?
Thanks for helping!
Thanks for helping!
