Evaddave 87gn
Always learning...
- Dec 16, 2005
After installing a Willwood Four piston brake setup on the front of my GN i noticed severe tire rubing when driving the car. I contacted Willwood and they said the spacing should change no more than 1/8 inch. After comparing with the stock rotor the change is 2 inchs!
SO this placed the outside edge of my tire into the outer edge of the fender well! I intend to change to a better offset in the front tires, but i have found the spacing is going to require a unique backspacing. SO this is what I did! I changed upper control arm shaft kit with the Moog kit that give the ability of better camber adjustment. I still had about 1/8th inch hit when brakeing or cornering... so! I took to a body shop who said there's not enough room to make any type of changes. I thought about it, and decided he was Full of IT! So heres my fix I gaind arounf an 1.5 inchs of clearance! Very easy just tkaes a little time, and with winter almost here nows the time. :biggrin:
