gasket matched and bowl blended heads fresh valve job and guildes new spring, and retainers. Jet Hot coated upper and lower intake, fuel rail, alt bracket, turbo bracket, throttle bracket, turbo shield. new not rebuilt alt, new crank sensor, new knock sensor,Kirbans heated O2, Kirbans adj fuel pressure regulator, Precision Turbo cam BV6-3A 268-8, new Rollmaster timing chain and gears,new high volume front cover, johns performance turbo oil feed line. mototron 60lb inj, TE-44 polished compressor side. stainless steel inlet and intercooler pipes, stock MAF. 9in K&N, Ramchargers dual fan, B&M trans cooler with -6 braided lines, all of Kirbans frame braces including rear seat, 3" THDP jet coated but not shiney like the intake etc, 3" ATR single shot new, new Optmia red top battery, UMI lowers.ATR sway bar, KYB's all around although are old. alum drums, 340 pump hotwired, caspers cam sensor tool and that thing that gives a false signal if cam sensor fails.2 1/8 VDO boost/vac guage in pilliar, have console guage 2 gauge holder with dummy guages in them, Commander chip,new shifter handle assembly with modfied gate where you have to push button in to shift out of 2nd, Pioneer CD player that fits the hole with remote, digital dash, kirban door jamb braces. NO posi, 87grill, have 86 also. new heater hoses, new upper rad hose, fuel pressure guage on rail, new ignition module, extra coil pak, Energy Suspension body bushing kit still in box,extra GNX bushings from Kirban, BRAND NEW trans 2 miles as of 6/11/05 with a 2800 restalled D5 PTS converter, case strecher servo, hardened drum, new TV cable. .please email with any other questions. aekujawa@comcast.net have appraisal from before modification for 10K $9k
thanks for looking
thanks for looking
