Testing waters on this.
What you will get:
-Gen7 dfi box
-External data logger and wideband controller
-adapter harness for a factory buick harness. Wires are long enough to put system under the pass seat
-I got a bunch of different tunes I will supply
-usb pro key
-3 bar map sensor
This is a great system if you are looking at ditching the factory ecm. It uses a bosch wideband that you can buy from autozone for less than $60. I am selling because I sold the v6 and am going a different route.
Things this ecm setup can do:
-data log without having a pc in the car
-great nitrous controller
-handle 160lb injectors
-get rid of maf sensor
-wideband correction
It will control the ac components, however I never used it for that. I had the ac controls bypassed where the ecm couldn't disable the clutch.
$900 shipped in the 48
I will give as much tech support getting this running for you I can. This should be pretty close to plug and play. You will have to tap into the map sensor wiring and run wires from the inside of the car to the engine bay for the wideband sensor. I will help install it if you bring the car to my house. If you are local. I will also go to the track or dyno with you to get it tuned to your setup.
What you will get:
-Gen7 dfi box
-usb pro key
-3 bar map sensor
