May 29, 2004 #1 J jpratt Well-Known Member Joined May 6, 2004 Messages 3,335 Fuel pressure = 32 and holds. Is this enough to run the engine? Wont start and everything else checks out fine, injectore pulse and spark.
May 29, 2004 #2 B blackstallion New Member Joined Jul 7, 2003 Messages 190 yes that should be enough to fire the car check your crank sensor
May 29, 2004 #3 J jpratt Well-Known Member Joined May 6, 2004 Messages 3,335 I already replaced the crank sensor. I am getting the noid light to flash when connected up to the injector harness.
