Fuel Lines Cracked
gr8regal
I have broken fuel lines at the fuel filter:confused:
Any Help with a vender, Buick doesn't know Jack::mad:
Russell,
Is this for your 84?
If you are looking to buy a set from the Fuel filter Up to the rail, and the other line that goes from the filter down....I have an extra set laying around.....If you are interested in them...Feel free to E-mail me.
Get a fuel filter with a barb on the end towards the broken line, and use a piece of fuel injection hose on it with double clamps.
Worked for me for the past 10 years.
Or else get a repair end and use the same filter but a piece of hose between the repair end and the fuel rail.
File the end of the broken line smooth on the inside and outside with round and flat files.
Make sure if you get a filter with a barb the flow is labeled on the filter in the right direction such as with the Purolator ones.
You can use steel braided hose as well if you want.
Or go with a new metal line.
