OK, I realize this is a little weak as far as fabrication goes, but I thought I would post it to give people the option.
I'm trying to downplay the racecar look on this car a little bit. I'm not a big fan of having gauges everywhere, so I wanted to hide the fuel pressure gauge so it doesn't stick out like a soar thumb (ie on hood). I am still undecided on whether I really like this or not.
I bent up a little bracket and used the existing holes for the power steering reservoir to hold the gauge tight and hold it to the car. I also tried to hide the braided fuel line the best I could, running it under brackets and such. This is a nice spot to have the gauge while you are adjusting pressure at the regulator. It also cuts down on the vibration that the gauge would be subjected to if mounted directly on the rail.
