I have a Kenne Bell adj Fuel Pressure regulator. I notice that after I turn it down to get my o2's in check, the FP creeps up over after a day or two.
There is a noticeable differnce in the way my car pulls when I get my 02's into the high 700's. But ir doesn't take long before they are back into the mid to high 800's.
Plus the I can't get it anylower than about 37lbs. If I put it to 36 I get a code 45 at idle and my 02's are very high at idle. I think that 36lbs would be perfect for the 14lbs of boost I am running on pump gas on the street.
My questions are could my regulator be going bad? And is there anyway around the code 45 issue with low FP? Thanks
Matthew
Matthew
