Fuel problems
TURBO 6
Beer Snob
Staff member
I'm not getting enough fuel to my injectors for some reason. I have Red's DP with 83's and stock fuel lines. I checked the fuel pressure under boost and it's going up, just like it should. My WB02 is showing 12.5's and the EGT's were in the 1750 range before i let off. I tried throwing more fuel in the FAST, but it didn't help. I don't understand why the FP is going up with the boost and I'm out of fuel. FWIW I have enough fuel for 127 mph, after that is when it leans out. Any ideas?
you positive both pumps are coming on?
that setup should supply plenty of fuel if working properly
for example, my injectors are at 65% duty cycle at 127 mph.....same 83's, ATR double, and the 02 is pulling fuel (11.5 a/f)
both pumps are coming on. I know I should have plenty of fuel. That's why I'm baffled.
they may be coming on, but they ain't pumping.........or you have a clogged filter/line
think I would replace 'em
Just changed the filter. I could hardly blow through it. I could easily blow through the new one. I think that was the problem.
Is there a spec for a volume test on the ATR twins?
I'm trying to solve an intermittent lean condition too and I'm
suspecting my pumps are getting tired.
