Fuel pump help
Steve-M
Upgrading fuel pump on my T and the new pump doesn’t match/connect to the hanger plug.. what are my options? Learning as I go with this so its fairly new to me
Ok, first lesson is you buy from a TB vendor. Racetronix makes a plug and play hotwire kit and a fuel pump that will drop right in and suppy the pump with a good clean 12v power that the stock lines won't.
https://www.racetronix.biz/customkititems.asp?kc=rfpk-006-g77
This is a good place to start. That pump should be good for 11s. It has all the upgraded wires you need, it will fit right on the hanger, has the correct rubber hose, and a new filter.
You have not listed your mods which would help us help you.
Yeah that pump is a racetronix walbro 255. Actually was given to me by another TR guy. My mods which are all recently purchased include, Te44, TA 3” Dp, 60lb injectors with TT chip. Nothing is installed yet, sent my headers to get welded/ceramic coated. Also since I’m upgrading injectors I ordered a new injector harness. Oh yeah and car has a stock locational stretched intercooler with a duttweiler neck.
Upgrading fuel pump on my T and the new pump doesn't match/connect to the hanger plug.. what are my options? Learning as I go with this so its fairly new to me
Just have to make sure you are running the + to the + on the pump and the - to the - might have to swap the wires around or pull them out of the plug in the hanger and put the "new" plug on the wires so it plugs into the pump. Have to look at it and make sure. Not hard but can be a hassle.
Ok, got it figured out. Had to purchase the g77 fuel pump installation kit from racetronix so my nee fuel pump plugs up. And found my car already has a hot wire kit ran, that’s saves time/ money
