fuel pump hotwire..
ProjectWE4
C. Horel
hey i was wondering on how to make your own hotwire kit.. i saw the way off of gnttype.org but is there any intructions with pics or anything or any easier way of doing this or am i just screwed haha.
thanks
1 30 amp relay, some 18 gauge wire, some 10 gauge wire, and misc connectors, done for probably 10-15 bucks.
What he said.
I cut the pump power wire in the trunk, just before it routes to the outside. I ran a wire back thru the same way the original wires are routed back, over the rear wheel well, thru the channel under the door sill, etc, to under the hood where it trggers the new relay. I mounted the relay next to the other 3 on the driver inner fender. Then a 12 ga wire back the same way to the rear of the trunk. Power from the alt, with a fuse, straight to the relay.
Measured voltage went from ~ 11.9 to ~ 13.2, I think. Long time ago, but it was significant.
