i recently bought an in the car fuel psi gauge & i have seen it at any where from 61 & 72 psi wot, i read some where the set up at 20psi of boost with vacuum hose off at 42-43 at idle & wot was 60psi was the hot set up. i have 42.5 lb inj. also a hot wired 340. just check to make sure fuel lines arent pinched, new fuel filter, good grounds and no vacuum leaks. oh yeah also once i kept hearing the whirrring noise of the pump over the summer or 2 ago get louder so i replaced the fuel sock & no more probs. since......waycross ehh i live 30 minutes from you i think theres another white -t runnin 7.20 or 7.30s your way, better not pull beside him LOL.
