Fuel pump?
May 21, 2017
240
17
18
36
Laurel md
All right guys I’m looking to upgrade my fuel pump I am going to be doing Champion Aluminum heads and intake and may be going to E85 in the future what pump should I do so I won’t have to go bigger later
marleyskater420
still needs to learn
Aug 14, 2004
1,660
272
83
32
Where mind expansion abounds
How much power you looking to make?
A DW400 is a better quality piece than a Walbro 450, but both will work. If you start running out of pump, strap a Boost A Pump on there and call it good. Still costs less than a double pumper setup.
May 21, 2017
240
17
18
36
Laurel md
I’m hoping for around 500hp
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,451
401
83
SoCal the high desert
I now have a dual 450 in tank setup . Regardless of what pump u go with you will need to get Teflon fuel lines and you might want to consider pluming in a ethanol analyzer to let you know the ethanol content of the fuel u are running
Jan 31, 2006
7,058
209
63
L.I NY
more info on the twin 450 set up please?
Top Bottom
