fuel pumps
ronbuick
I think I need more fuel or a new pump. I have had my pump for about 3-4 years with only 2-3k miles on it. do not want to go to a double pumper, I have Red's in it now, anyone make one a tad bit more powerful with out going to a dbl. set-up. I have 009's now and thinking about going to 60's, also have Razor's kit to.
thanks
Ron
The obvious question is why do you think you need more?
The use of alky requires *less* gasoline.
For the same reason, 009s are a good choice with alky.
Do you have evidence you're going lean?
At your performance level, high 11s, if your pump's in good working order and considering you're running alky a new pump and injectors aren't called for...
strike
My EGT's are higher than before the install of the alky kit or is that normal with alky?? or my pump could be getting weak, that is the reason for the question on the pump, if my pump is getting weak and cannot keep up is there one that is a tad bit more powerful than Red's or a 340 walbro that I can replace it with if I need to.
Ron
