The fittings used in the fuel system for the turbo Regal are Saginaw (metric O ring type)
Fuel injection feed 3/8" Saginaw - tube nut thread:16mm X 1.5 - O-ring part GM number: 22514722 (7.35MM ID X 1.66MM Thick)
Fuel injection return 5/16" Saginaw - tube nut thread: 14mm X 1.5 - O-ring part GM number: 22516256 (6.07mm ID X 1.30mm Thick)
Earl's adapters from -6AN to Saginaw (metric O ring fittings)
Part # . Metric Thread . AN Male . . .Bump O Ring Male to AN Adapter
991955 . 16mm x 1.5 . . -6AN . . . . Fuel Injection / Power Steering Adapter. Male -O-Ring Seal (3/8 inch Fuel supply line)
991954 . 14mm x 1.5 . . -6AN . . . . Fuel Injection / Power Steering Adapter. Male -O-Ring Seal (5/16 inch Fuel return line)
991956 . 18mm x 1.5 . . -6AN . . . . Fuel Injection / Power Steering Adapter. Male -O-Ring Seal
Part # . Metric Thread . AN Male . . . .Bump O Ring Female to AN Adapter (Handy if replacing Fuel Filter)
9894DBJ . 16mm x 1.5 . . -6AN . . . . Fuel Injection / Power Steering Adapter. Female -O-Ring Seal (3/8 inch Fuel supply line)
9894DBH . 14mm x 1.5 . . -6AN . . . . Fuel Injection / Power Steering Adapter. Female -O-Ring Seal (5/16 inch Fuel return line)
Fuel supply line uses Saginaw 16mm x 1.5 fittings at:
* Either side of fuel filter . . . . See adapting to the fuel filter below:
* End of the fuel supply line at frame on drivers side of engine,
* Into the fuel rail on passenger side.
To adapt AN fittings to the engine fuel supply points use:
* Earl's # 991955 to adapt the Saginaw 16mm x 1.5 male fitting to a -6AN male fitting
*Then Earl's # 165006 -6 AN Male to 3/8 inch Hard Line Tubing Adapter
To connect the GF 481 (AC) standard efi filter to 3/8 lines use:
* Earl's fitting # 991955 to adapt the regular 16mm x 1.5 female fitting to a -6AN male fitting. Then:
* Earl's #165106 -6AN Female to 3/8 Tubing Hard Line Tubing Adapter
* or Earl's # 581806 -6AN 3/8 Tube B Nut, if you flare your own tube end, be sure to get the tube sleeve that goes with the nut
* or Earl's # 800106 Straight -6AN Female to Swivel-Seal -6AN Hose End
Fuel return line uses 14mm x 1.5 Saginaw fittings at
* End of the fuel return line at frame on drivers side of engine
* Out of the fuel pressure regulator on drivers side
To adapt AN fittings to the engine fuel return points use:
* Earl's # 991954 to adapt the Saginaw 14mm x 1.5 male fitting to a -6AN male fitting
*Then use Earl's # 935106 90Deg. Tube Bend, -6AN Female to -6AN Female
*Then Earl's # 165056 -6 AN Male to 5/16 Hard Line Tubing Adapter
