turbowannabe
- Dec 6, 2001
Hey guys,
Well like the subject says, I just full throttled my 87 GN, for the first time since I've gotten the motor in, today. The fresh motor has about 1300 miles on it now, all stock with a fresh bottom end crank cut 10-mains 20-rods. I'm running a Joe Lubrant 23* 50#inj. 100 octane or alky chip, which I think may be part of my problem. I don't have the alky going right now, since I need to put in some new wiring but I was running around a half tank of 93 octane with Outlaw octane booster added before I went out and got on her. My BlM's pretty much stay at 150 at idle and a little under at cruise speed, and my INT numbers look a lot better it fluctuates between 128 and low 140's at cruise, will pop up to 150 when I sit at idle for an extended period of time.
So, when I go out and mat it, I check my scanmaster and it records 781-02's and 14.5-knock retard at 100mph
. But, I'm thinking that it's at least partially false knock since the car seems to be running really good and I did not notice any odd noises whenever I get knock reading. I do have a BGC 23-row stretch intercooler in which the shroud is rubbing against the sway bar, and this crappy Poston's 3" downpipe which periodically hits the frame rail. I just moved up to chicago, and am waiting till I start automotive school at UTI until I can do further tuning and such. Like I said, I can't ever hear hear anything that sounds wrong when getting on it, and I would figure I should be able to feel or hear SOMETHING with readings like 14.5 degrees of knock retard. It runs really strong, but I get very small knock readings sometimes over 10psi and that damn 14.5 reading I got around 17 psi.
I've replaced damn near all of the vacuum hoses, and get no malfunction codes. But, I know 150 blm is not good at all, my integrator looks a hell of a lot better and my O2's fluctuate just like they should whenever I'm driving it normally. Let me know what you guys think, I know I'm definately NOT going to be doing any more WOT and am just going to keep driving it as slow as possible with staying under 10psi.
thanks
-Dan
thanks
-Dan
