In the year and a half that Ive owned my car, Ive heard the gas tank go pshhh after removing the gas cap, like once. Cap is good. Charcoal canister solenoid is good. Solenoid O-ring is good. All hoses are good (that I can see). If Im not getting the pshhh sound, do I have serious problems with my fuel system? Think that some of my crappy mileage could come from simple evaporation since the tank isnt pressure sealed?? Although it does take awhile for gas to evaporate, and I go through 10 gallons every 2 1/2 days so it doesnt really have enough time to evaporate. Ive checked the whole fuel system for leaks, including the gas tank itself, and Ive seen nada.
Even with the solenoid working (I verified it in the lab here at work..it was sticking but I fixed it), could a charcoal canister issue that I cant see, be causing the lack of tank vacuum?
If theres anything I can do to regularly get that pshhh sound, I'll do it. Its always bothered me that it doesnt. What should I look for? The check valves are cheap replacements that were on there when I bought it, and they dont work GREAT, but they do work. It does flow a tiny bit in the wrong direction. But not enough to completely drain the vacuum out of the tank in 5 seconds.
