Gear drive
dank GN
BlackArts Automotive (661)993-8277
I have a single bolt gear drive that including the oil plug inserts you install for the mounting on the block . Also the cam nose gear . The single bolt idler gear is stronger from what I have read . All that’s needed to run this in a on center block is a cam and balancer spacer . It will work with production blocks as well. Looking for $250 shipped
