Loosen both screws, pull sensor forward, slightly snug screws and tap gently up or down from there to achieve target, once target is reached tighten screws. The voltage will be slightly higher with car running so compensate for it. For instance the key on engine off tps set to .40 at idle with engine running it normally will get closer to .42
