I was wondering what it would take to get the most out of the stock turbo. My plan was to get an alchy injection kit and a boost controller, in addition to a scanmaster for tuning. In my research in this site and other sources thus far, I cannot tell whether or not the stock fuel system (injectors mostly) will handle additional boost. I plan on:
Doing the "spring cleaning" which will include a new fuel pump and hotwire
Purchasing and installing a scanmaster, boost controller, and SMC alchy injection kit, as well as, most likely, a cold air intake
Do you recommend chip and injector upgrades? If so, what size? Also, how much boost is it likely I will be able to run on the alchy injection before knock becomes an issue (I can tune boost up slowly to find this out, but I want an idea of benefit to cost ratio before I take this upgrade path). I have boost and knock, oil pressure and water temp gauges. Do you recommend the addition of an adjustible FPR and fuel pressure gauge as well? What about an EGT gauge? Will the stock intercooler handle much higher than the stock boost level?
I know it's a lot of questions, but I've spent a couple of days reading different stuff and don't yet know what is going to be required to maximize the use of the stock turbo, or if it is even worth going that route rather than modifying with a certain upgraded turbo in mind. Thanks a lot for the help guys.
