Warp6
Mine since '92
- May 25, 2001
Fixed all the broken studs for the girdle. Got the Duttweiller cork pan gasket. Now, should I use sealer or put on dry? What's the correct and total method for putting this pan on. I think I'm supposed to put sealer in the stud holes with the sealing washers to seal girdle. I have the engine out, girdle on and torqued down (25#) I have the silver metric washers under the stud nuts and have not put the copper sealing washers on yet. How are you guys doing it?
Do I :
1) fill the stud holes with sealant
2) drop the copper washers on
3) put gasket on (block dry)
4) put pan on (pan dry)
5) torque pan down (88in pounds)
Do I :
