I am about to run some top engine cleaner through my Buick, but I have a couple questions first. I recently (less than 300 miles ago) had my cylnder heads gone through with a valve job, valve seals, ect. so I there probably is not much carbon built up on the heads. Will the top engine cleaner still produce massive amounts of smoke enough to double check for exhaust leaks?
Also, can I just dump the top engine cleaner into my alky tank, and hit the test button to introduce it into the engine?
Ian
Ian
