GN cruise control??????
Polak420
Black Sunshine
Hello I'm looking to get the cruise control option put in my 87 GN is there anything else that I need besides the cruise control diapharm and, the cruise control turn signal stalk?????
Thanks for any info,
Polak420
You'll need the little box that goes under the dash and mounts right above the accelerator.
I'm not sure if this came on all cars and if it does other things, but I do know it is part of the equation.
Your turn signal stalk should have the cruise control features on it, no? My '87 T has it and doesn't even have cruise control. I thought it was broke when I first got the car...
you also need any wiring that goes along with the CC. More importantly you need th CC switch that mount right below the brake switch down by the brake pedal. This swithc will disengage the CC when you hit the brake.
