GNX dash speedo problems (Code 24)
smallv6
Still in Block Learn Mode
I have been experiencing intermittent speedo problems with my
GNX dash that I purchased last year from GNXdash.com
I keep getting code 24 and the speedometer will just stop working. Then, it will just start working again.
Could it be the VSS unit that came with the dash kit is giving up the ghost? Or could it be another issue.
Thank you for your time.
Have you called me and asked me about this problem?? Is it a mechanical or electronic speedo? Sounds like the VSS signal is dropping off. Could be the drive pin is installed backwards between the VSS and the lower speedo cable or your lower speedo cable may be shot. Call or drop me an email, we'll get it fixed!!
Tom Houser
Performance Instruments
www.gnxdash.com
Thanks Tom, I will call you in the A.M. It might be the cable
It was disconnected from the tranny over the winter because of the re-stall on my convertor. It does seem weird, as it worked perfectly last summer.
Thanks again :)
