flare install
the flares basically bolt right on, I found it easier to remove the wheels and try fit the flares to make the body lines match up. also make sure the fender to flare gap is as small as possible, you might have to move the flare abit to adjust it. I found it easiest to pre drill holes in the flares to prevent them from cracking when tightened. I also used the holes as a guide to drill my fenders to get the holes to match up. I used hardware stainless screws with a big flat head to secure them. It took me about an hour to put them on taking my time. Good luck hope this helps
