Going to build a 4.1,have questions.
sixgun86gn
six offender
I am going to pick up a 4.1 block and I have some questions on building it.Where can I get 8to 1 comp.forged pistons for it? Will the same billet main caps for 3.8 install on one of these blocks?Would a LT70 still have alot of lag with the extra cubes and my 3200 stall?I want to build it for the 10s.LOW 10s.
Nobody knows?!I can't believe that.I know some of you are either running or building a 4.1.
I can supply custom forged pistons with correct dish for 8:1.
The caps for 3.8 will work on a 4.1.
Don't know about lag, but a TE-70 with a 3200 stall will be a dog off the line. Sounds like too much turbo unless you have killer heads?
I plan on putting GN1s or the new T/A heads I have been reading about.Also Is there anything I have to do to the heads to mate them to a 4.1?Im also thinking of a cam of about 218 duration at.050.Any cam suggestions?Intercooler ,I will e-mail you.
I've been in one 70 series turbo car that was running real low 11s, and it had a slick 3,600 stall converter. Was also tuned pretty well. It wasn't bad, but it took til 3,500 for all the components to synch up and go.
I'd suggest you get a ride in a 911 converted car before locking yourself into what you have. I was in a car with a 4,000 stall 911 and it was just amazing.
Lots of this lag stall discussion, IMO, is just the lack of getting the accleration enrichment right in the chip.
I currently have a te63 on my car right now and it spools real fast.I have a vigilante 9.5 lockup stalled at around 3200.I was thinking with the extra cubes it might stall at about 3500.I can always get it re stalled.I like the vigilante it pulls real hard.
Your e-mail kept bouncing back so here is what I wrote. Some may be off slightly as I can't remember all the numbers:
I got all my parts back from the machine shop before leaving for Texas for 3
weeks. It is still sitting in the wrappers so over the T-day Holiday I plan on
putting it together. The 4.1 gains benefits of everything a 3.8 does. Have you
looked closely or done any research on a 4.1? Let me tell you what I know from
doing research and measuring:
-The lifter valley of course is open style without bridging from one side of
the block to the other. Excellent idea to grab a Dremel and knock the sand-
casting flash (roughness) off the valley holes so they can never chip off and
fall in the motor. Also helps in preventing some of the stress risers in this
area.
-The rear main actually mics out a little thicker than a 3.8 but it is
marginal. Not a problem area in either but thought you may want to know.
-I had a 3.8 109 block sonic checked compared to a 484 casting (best 4.1
production available)and the deck of the 4.1 is .125" thinner to start with.
This is a known problem area as some of the 4.1's are cracked before even
turboing them. Have your block magged! If nothing else the decks and cylinder
walls. The 484 casting has a couple of extra reinforcement ribs like the later
109 3.8 blocks which make them stronger.
-All 3.8 109 blocks have their anchors for the head bolts down deeper in the
cylinder. The 4.1's threads are right up top at the deck surface. Great idea
to chamfer the top of the thread to help prevent a crack starting there.
-The cranks, rods, cams are the same. The 4.1 takes different cam bearings
with all together different oiling holes than the 3.8. Pistons are much larger diameter. I think 3.965" for standards .
-You can get Speed-Pro rings or a set of Total-Seal second rings but they
don't make a top ring Total-Seal to fit a 4.1.
-Your 14 bolt oil pan will not be baffled like the GN 20 bolt oil pan. You
will have to get one. They only come on the 84 GN with a 14 bolt pan and you
will pay dearly for it. I got one from a close friend for $65.00. It was
rusted so I had to blast and powdercoat it. I have since picked up a mint one
off of E-Bay for a steal at $35.00 as a spare. I flipped the oil plug to the
outside before doing this so all the oil will drain. If you don't about 1/4
quart will still be there with any metal or debris.
-They make a girdle to fit a 4.1 to add strength just like the 3.8 20 bolt.
The caps are the same if you want to go billet.
-The 4.1 takes different head gaskets than a 3.8 to accomodate the bore.
-You will need a universal or 14 bolt front cover to fit the oil pan.
-The turbo drain back hole in the front of block is not drilled. You will have
to have the 3/4" NPT thread put in for this.
-Without a doubt check your pushrod length because it will differ if using 3.8
pushrods.
-The 445 casting heads are better than the 293 casting 4.1 heads. Use them.
-The 4.1 has a different flywheel with weights. Use it.
-The siamese bores of the 4.1 leaves thinner cylinder walls. Bore just what
you need.
The production 4.1 is nothing like a Stage 2 4.1 motor and to push 600 HP or
low 10's is asking for trouble. If you do the girdle and other things it may
last a while if the block doesn't split in the valley. I don't plan on going
past 10.8 with mine so here is what my 4.1 build consists of:
-Studded bottom end with billet center caps. Line bored .005" with
a .010"/.010" turbo crank.
-.020" bore with Hyperutectic pistons. I catch grief all the time over them
but I like them. They have worked well for me. Shelf 4.1 pistons are none.
They are custom so $600.00 is what J&E gets for the forged 4.1's. Lee Thompson
had/has the fastest hot-air 4.1 known and ran a production 4.1 with Hypers to
11.2 hot-air and didn't lose one. Up to you. Hypers are $150.00. Polish the
tops and you are golden.
-Total-Seal second ring setup
-Chamfered deck
-Head studs. A must on a 4.1. It will help a bunch to equal the load exerted
on the deck and will help keep it from cracking.
-ARP Pro-Series rod bolts
- "H" series bearings with wide rods
-Fel-Pro 1000 head gaskets. Never tried them but that is what fits and that is
what Lee liked. The 1007's would work nice too but I am not set up that way.
About all I can think of right now. If you have more questions just ask.
I've done alot of research on the 4.1 also. And by my sign u can see what I have so far.
My block is square decked,sonic checked,Lifter Valley has been filled with ti-putty,turbo drain drilled in front of block
Block has been filled with block hard 1.75" from deck
Head bolt holes have been radised and stress relieved
The pistons are for 4" Bore. The Cr is 8.9 with 50cc chamber. They are Forged with 1/16 rings. They have Chromemolly pins .927 floated. They have valve notches for Large lift cam. They were custom made for Turbo application. They would require rods to be bushed for .927 floating pin which is for SBC. I also have Plasma Molly ring set for pistons all is brand new. With a 4in bore u can
go with any chevy 350 ring. The lifter valley was Ti-puttied to re-inforce it and make it stonger. I had the 3/4 hole drilled on the front but u can send the oil drainback to the oil pan if u want.
My block has hardblock due to the fact the walls are then and weak. U can drive it on the street for 40-80 miles but u have to
watch your oil temps not the water temp due to the only cooling the walls are getting is the bottom of the rings.
It all depends on what your goals are.
There is more things I can tell u and would be happy to e-mail also. Jesse is right on his stuff and Nick micale knows alot also due to fact he is helping me out on this motor. :D
Without a physical anchor (attachment to the block) like the 109 has in its valley I doubt the putty doing anything other than just laying there. The force you are trying to prevent is it ripping apart there. I see a Hard-Block fill doing what it is intended by reinforcing the cylinder walls but the putty would need an anchor point other. Devcon is probably similar to the putty.
Jesse,
Thats what I got is Devcon putty. That stuff is bullit proof.
The Devcon Ti putty is extremely strong and has the same
coefficient of thermal expansion as cast iron. Alot of the Buick,
Olds, Pontiac guys Devcon there lifter vally due to the open design which is weak. I'll take some pics of my shortblock with the
Devcon Ti-putty.:D
Great.Do you think that some kind of bracing can be machined and anchored to the block in the valley?Maybe I am shooting too far for a 4.1 production block and should just concentrate on breaking into the high 10s.Thanks intercooler for the info you have answered all my questions and then some.What cam do you reccomend?
Would a 9:1 compression 3.8 have similar torque to the 4.1 with 8:1 compression? Hmmm...... :confused:
QUOTE] Great.Do you think that some kind of bracing can be machined and anchored to the block in the valley
sixgun86gn,
Thats what the Devcon Ti putty is for its for bracing it and making
that area strong like a 3.8 block.
Get a roller if you can afford it. If not a flat tappet will work fine. I had a 208/224 flat tappet for my 4.1 but someone on the board bought it and my 204/214 so I ended up with the 206 roller. My plans then switched to me blowing up the 3.8 with the 206 then swap it over into the 4.1. Cams in these motors are weird because just about any work. With a given combo one might hit it dead on and go a little better but only .2 or so. Get something in the 210-220 range and it will rock!
I don't think the Devcon will do much for strength in the valley. I don't have proof but my shop guy said it wouldn't gain me anything. One way to test it would be with a scrap piece of iron (like a head) and make a pour off to the side of it like a foot peg. If you can stand on it and it doesn't snap off or lose its adhesion it may be worth it. I can almost bet it will let go where the adhesion isn't good enough to hold on the cast iron. We use Devcon to fill the EGR passages in heads like a plug but when it cures it is held in place by the shape and angles. If at any time it starts to flake or crack up in your lifter valley you can kiss your motor and parts good-bye!
Thats some great info Intertcooler...I've been an avid reader of TB for a very long time and just reciently got a winter projet 4.1 and this info will prove very useful
Jesse,
I've done my homework and I believe the Devcon Putty will not crack or move. I can bet u this stuff not going to crack. It took
3-4 Ti drill bits to drill the oil holes.
They use the putty in 455 Oldsmoblie and Buick motors and those motors produce way more Hp and Tq.
The same motor I'm building Lonnie Diers built awile back with
Ti-putty and hardblock 4.1 and made 685 Hp before the rods or crank took a crap (can't remember)
My motor not running yet but will be soon and will see what it does. I'll either sink or swim on this 4.1.
If u choose a cam use a 210 and up due to the 4.1 is 10% biggier then the 3.8. I went with a 220/220 roller but any cam biggier than 210 should be good enough like Jesse said.
Hypo pistons are kind of scary to me due to fact they can shatter or break and cause alot of damage. I've seen mustang motors and chevy motors with Nos or procharger and have Hypo Knock the walls out. I went with forged due to the fact there strong and dependable and can take dentnation.
Jesse remember I have your 83lbs and maxeffort and there going on the 4.1;)
And get that 4.1 going and come back to Az and we can have two
White Gn go at it:) :D ;)
