Hey gang! Sorry I need to sell my GN for a truck or SUV for work. It was Keith's car before I picked it up. Nothing wrong with it, I just need something with more storage space. The only small prob I have is that we just installed a dual Ramcharger radiator fan set to manual mode. If I had more time, I would configure it for an auto mode but I do not have as much time as I did before. Following is a list of what is in the car. Selling it at $15,000 OBO. Pic at http://gnregistry.netnet.net/details.phtml?id=494
Let me know. Take it fast and easy!
1987 Buick Regal Grand National
VIN#: 1G4GJ1175HP464817
Registered @ www.GNRegistry.com as BGN00494D
Body Mileage: ~132,650mi.
Engine Mileage (Rebuilt): ~6,000mi.
Transmission Mileage (New): ~6,500mi.
Transmission, Rear end, engine oil replaced ~500mi.
Carfax Document shows clear title & no major accidents
Power Windows, Door Locks, Mirrors and Driver Seat
G80 Option (posi rearend)
Air Condition converted to R134 Refrigerant
ENGINE:
231ci V6 bored .030 over (109 block)
Engine Balanced & Blueprinted
Postons .030 Hypereutectic Pistons
Postons GN110T Cam 212in. / 206ex. @ .050 Duration
Ported Stock Heads (1.77/1.50)
Heavy Duty 100lb. Valve Springs
PTE-51 Turbo w/ .63 AR Housing
K&N Cone Filter
Chrome Plated Aluminum Intake MAF Pipe
Blue Silicone Turbo Hoses & New Up-pipe Hoses
Heavy Duty Adjustable Wastegate Actuator
Bosch 868 36# Injectors
Bosch Adjustable Fuel Pressure Regulator
Rail-mounted Fuel Pressure Gauge
SMC Alcohol Injection
Ported Stock Intercooler
RJC Power Plate (Plenum Spacer)
RJC Rocker Shaft Supports w/ New Rocker Arms, Shafts & Retainers
Postons 2-Piece 3" Downpipe
Ported Stock Elbow
Dual 2.25" Dynomax Super Turbo Exhaust
ATR 3" Stainless Steel Test Pipe w/ Dump Cut-out
High Volume Stock Replacement Radiator
Carter Heavy Duty Water Pump / 160* Thermostat w/ Billet Housing
Ramcharger dual radiator fan
Billet Aluminum Overdrive Water Pump Pulley
New Upper & Lower Radiator Hoses
Walbro 340 Fuel Pump w/ Hotwire Kit
Rebuilt Oil Pump
Oil Pump Booster Plate
RJC “Biggie” Oil Filter Adapter
New Upper & Lower Engine Oil Cooler Hoses
Fram PH11 Oil Filter
Rebuilt Alternator
New Dayco Serpentine Drive Belt
Exide Heavy Duty Battery
Vacuum Brake Conversion Kit
Alternator Bracket Torque Strap
New Heater Core
New Wastegate Solenoid & Boost Lines
Grainger Valve (not installed)
Chrome Turbo Heat Shield
ELECTRONICS:
Joe Lubrant 92 Street Chip & Thrasher 92 Chip w/ anti-theft feature
Scanmaster 2.1 (scan tool)
Autometer Tachometer, Boost and Oil Pressure Gauges
TRANSMISSION:
Art Carr Extreme 200-4R Race Transmission
Art Carr 10” 2,800 Stall Torque Converter
Art Carr 10,000GVW Transmission Cooler
TIRES & SUSPENSION:
Enkei 16x9 Silver Mesh Style Wheels (Manufacture Discontinued)
BFG 245/50 ZR Tires (Front)
Bridgestone Potenza 255/50 ZR Tires (Rear)
Air bag in rear springs w/ valve stems at rear bumper
Rear Tall Pinion Snubber
Rear Boxed Lower Control Arms
Polyurethane Suspension Bushings
Six Lower Body Frame Bushings
Front Diagonal Frame Braces
Monroe Gas Shocks
STEREO:
Sony Xplode remote control stereo
3.5" Polk Audio EX351A Dash Speakers
5.25" JBL DS55 Door Speakers
6x9" Kenwood KFC-6907 Rear Speakers
MISCELLANEOUS ITEMS:
Grant GT Steering Wheel
Steering Column lock
HR Parts Custom Billet Shifter
Carpeted Dash Cover
Aluminum Dash plate
GNX fender vents (not installed)
Floor Mats
Spare Tire Cover
Fire Extinguisher
Silver Platinum Tint
HPD Windshield Sticker
Flashing Center Console LED
“Buick Motorsports” Coil Pack Plate
“Buick Motorsports” Window Decals
ENGINE:
K&N Cone Filter
Ported Stock Elbow
Rebuilt Oil Pump
Rebuilt Alternator
New Heater Core
ELECTRONICS:
TRANSMISSION:
TIRES & SUSPENSION:
Monroe Gas Shocks
STEREO:
Carpeted Dash Cover
Aluminum Dash plate
Floor Mats
Spare Tire Cover
Fire Extinguisher
