B bluegate Member Joined Oct 8, 2016 Jul 15, 2019 #1 My grill has the terrible whistle at highway speeds. Any thoughts on why? Sent from my SM-N950U using Tapatalk
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Jul 15, 2019 #2 Maybe there's a gap between two of your teeth?
B bluegate Member Joined Oct 8, 2016 Jul 15, 2019 #3 TurboTGuy said: Maybe there's a gap between two of your teeth? Click to expand... I tried to word it so this road was not travelled [emoji3] Sent from my SM-N950U using Tapatalk
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jul 15, 2019 #4 what makes you think that the whistling sound is coming from your front grill ??
B bluegate Member Joined Oct 8, 2016 Jul 15, 2019 #5 Buckshot G/N said: what makes you think that the whistling sound is coming from your front grill ?? Click to expand... I removed it and no whistle. Wondering if the grill is missing something. It does not have the springs, its ziptied at the bottom of the corners along with the 10mm screws at the top. Sent from my SM-N950U using Tapatalk
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jul 15, 2019 #6 Strange { 86 or 87 Model GN } And with it being zip tied does it still allow you to still push bottom of the grill in with out the springs.
B bluegate Member Joined Oct 8, 2016 Jul 16, 2019 #7 87. No movement in the grill. Here is a pic from the back, maybe something is missing. Sent from my SM-N950U using Tapatalk
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jul 16, 2019 #8 Looks intact to me . what speed does the whistling start, and does it get louder the faster you go ?
B bluegate Member Joined Oct 8, 2016 Jul 16, 2019 #9 Usually between 65-75. Not noticeably loader with speed. Sent from my SM-N950U using Tapatalk
B BuicksBad Ur favorite Drug Dealer Joined Apr 10, 2019 Jul 16, 2019 #10 Heres a photo of a NOS grill.
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jul 16, 2019 #11 Looks like you need a new grill, or a good used one to stop whistling.
B bluegate Member Joined Oct 8, 2016 Jul 16, 2019 #12 Yep. Thanks guys Sent from my SM-N950U using Tapatalk
F Frederickdav Active Member Joined Oct 10, 2014 Jul 16, 2019 #13 I think it's the zip ties that are making the noise. Leave them off and see if it happens.
B bluegate Member Joined Oct 8, 2016 Jul 16, 2019 #14 Good thought, or even the hole they go through Sent from my SM-N950U using Tapatalk
