GTA Wheel Tire Size
rc1626
I've got myself a set of GTA wheels, two fronts , two rears that I'm going to be putting on my TR. I'm going to go fronts on the rear and rears on the front w/ spacers. I've done some searching on the board w/ regard to tire sizes and am still unsure as to what size tire I can run on the front using the GTA rear wheels? Can I go with 245 50's? I plan to run 255 50's on the rear. Any suggestions on tire brands would also be appreciated. Thanks!
Rob
should not be an issue at all thats what i run the fronts will rub a bit under full lock but how often are you at full lock?
dont worry abou it
I have the same wheels as you, and I'm pretty sure mine are 225-50's with spacers on the front and they still rub when I turn the tires hard each way. It just makes hard turns while backing up and such a little more difficult. On the rears, I have 245-50's. When I go for a ride later tonight I will make sure that's what I have, but I'm pretty confident about those sizes.
-Dan
Tire size
The stock size tires on the GNX are 245/50-16 front, 255/50-16 rear. I went with Dunlop tires, which has those size tires. I went with 4 TA front wheels all the way around and they fit with out any spacers.
