guage pod help, suggestions, opinions.
blown okie
Chuck Norris Approved
finally got the rebuilt engine in the '86 gn, and started it, but still need to hook up guages, i'm putting auto-meter 2 1/16 ultra-lites in the pillar,- fuel pressure, vac./boost, oil press., my question is should i go w/ the full replacement pillar, or the triple pod that attaches to the stock pillar, and the reason i ask is b/c I put the full dual pod pillar from ESP in my '84 T, wasn't happy w/ how it fit( or didn't fit) and was wondering if somebody else made the full pillar that actually fits, or should i just use the triple pod that attaches, all opinions, suggestions, or personal experiences will be much appriciated, thanks
Hi-
I suggest using the multi-hole pods if the full pillar does not fit properly. I would rather do that than look at a poor-fitting, full pillar. Of course, you will want to test-fit any pods you buy.
If you are thinking about the full pillar because you do not want to drill holes in your original pillar, you can get a Regal pillar from junk yard or someone who has spare parts or is parting out a car. If the color is wrong, correct color spray paint is available or your local pro, car paint store can mix it for you.
You can also get a dual gauge pod for the console tray to supplement any gauges in pillar.
Hope that helps.
Steve
