hard vacuum line ID - '87 GN
Blazer406
Mechanical Engineer
I have a hard line coming across the back of the firewall... behind the A/C box shield... and goes around the blower motor and down into the black where I cannot see it. I think this is the HVAC vacuum line.
There is a second one going there also... but where it goes behind the shield.... it doesn't come out (toward the middle of the firewall....out from under the heat shield) that I can see.....
Is that confusing enough?
It is like I have one line going in (from the middle going toward the pss side.... ) and two separate lines coming out and traveling around the blower motor going into the car...
It isn't the map sensor... I already have it hooked up...it isn't the heater valve...as it is hooked up....
Any ideas?
One connects to the vac line by the EGR solenoid. That's for the hvac controls. The other connects to the heater control valve going to the heater core.
Ahh..... I got mine hooked up wrong..... duh.... the heater control has to hook into the heater valve to send the hot water thru the core..... duh..... I'm such a putz.
Thanks.
